Will this steeringwheel fit my UrS6?
  • Fredz0r
    • Feb 2009
    • 51
    From an 'OEM-plus' kind of view I am thinking of replacing the steeringwheel of my UrS6 for this one: http://i.ebayimg.com/03/!BU0+oPw!Wk~$(KGrHgoOKkYEjlLmY4pPBKPjPHw1Tw~~_1.JP G
    But the obvious question is; Can anyone tell me if this will fit directly?
    Thanks peeps!
  • Fredz0r
    • Feb 2009
    • 51
    Ofcourse this is the right link: http://i.ebayimg.com/03/!BU0+oPw!Wk~$(KGrHgoOKkYEjlLmY4pPBKPjPHw1Tw~~_1.jp g
    • Andreas
      • Nov 2005
      • 731
      I thought I could help you with the pic <:
      I think it should.. but depending on what kinda steeringwheel you've got right now there's different methods for switching over to that one.. search the forum and you'll see.. i switched over from an earlier model/type airbag steeringwheel to one like that one myself in my s2 sedan!
      EDIT: the leather on that steeringwheel looks a bit worn? low priced I hope??
      EDIT2: here is the thread with all the info for switching steering wheels you need! http://www.s2forum.com/forum/showthread.php?t=21406
      Andreas Lundstroem
      A4 STCC Avant -04
      Audi /S/2/ Sedan -94
      prev.
      Audi /S/2/ Coupe -91
      • Fredz0r
        • Feb 2009
        • 51
        Thank you!
        At the moment I have this one: http://cgi.ebay.de/AIRBAG-Lenkrad-OR...ayphotohosting
        But now you mention it...I believe you are right...would the wheel be really that worm out? It is nog that expensive I think but I am to accurate to allow any worn out things in my vehicle
        • Fredz0r
          • Feb 2009
          • 51
          I According to this thread....I am still confused, but I think it will fit. Hoping for someone who knows for sure...
          Still not comfortable about the worn-out issue though...
          • Andreas
            • Nov 2005
            • 731
            If you now have the steeringwheel you posted then YES the other one should fit directly BUT there are 2 versions of that steeringwheel and they look ALMOST THE SAME, the older one is slightly sharper round the edges and then there is the one you linked/posted that is the newer one which is a bit rounded off around the edges!
            I had (of course) the older one... grr... I'll try to find ya a picture of the one I had!
            EDIT:
            I had this one from the factory (the break-point seems to be 1994-1995):
            Can you see the difference between the one I had and the one that you linked?
            I switched to this one:
            Andreas Lundstroem
            A4 STCC Avant -04
            prev.
              But the obvious question is; Can anyone tell me if this will fit directly?Thanks peeps!
              The answer is No and Yes. No it's not a direct plug and play swap. Yes, it can be done. I (and others) have done it. I have a 97 UrS6 steering wheel in my 93 UrS4. The best procedure for doing this is written up in a link within this post (made by me) - follow the link to the pdf procedure:
              http://forums.audiworld.com/showthread.php?p=18907988
              • Ruffiano
                • Sep 2007
                • 1458
                Your PDF is dead
                  Oops.
                  Originally posted by Ruffiano
                  Your PDF is dead
                  It's not just the pdf. The whole s-cars.org website is gone (??)
                  I have the pdf on my computer (at home) and will post it up tonight.
                  • Andreas
                    • Nov 2005
                    • 731
                    If his car is a late 1994 or newer (1995+) then its a plug n play fit, totally different than a early 1994 or previous then it is a bigger job (as described earlier)
                    Andreas Lundstroem
                    A4 STCC Avant -04
                    prev.
                    • Fredz0r
                      • Feb 2009
                      • 51
                      Thanks for al this peeps! At this moment I have the steeringwheel that Andreas called as the 'newer' one. So not the old one he had. My car is an UrS6 build in sept. '94 (so late 1994 Andreas!). So my conclusion for now with all the help of you people is: It will fit directly
                      But Urs4Boy; I am very curious about the PDF...
