H&R Springs, which way is up?
  • mcandmar
    • Apr 2004
    • 5118
    I'm in the middle of replacing the springs on the coupe and ran into a puzzler. I always fitted the H&R's springs so the writing is the correct way up.
    Something didnt look right so i stuck my head under the avant as i fitted them a month ago and found they were the other way around.
    Pic below i took years ago when i bought the first set for the coupe, they sent me avant ones by mistake so i took a few pics of them side by side.
    As you can see the coupe and avant springs contradict each other, so the question is which way is the correct way to fit them
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • Flat on my back
    • Jan 2007
    • 2449
    Isn't the finishing coil at each end slighting different?
    They were on the spare fronts i've got...so the tighter coil should got to the top.
    Hth.
    Carlos.
      The base of the spring should sit flat, the top of the spring has a slight helix angle to it and sits in the top mount cup. HTH
      • mcandmar
        • Apr 2004
        • 5118
        Thats how i had the old set fitted, closer wound section to the top.
        So i guess that means i put the avant ones in upside down, looks like i'm taking that one apart too
        • mcandmar
          • Apr 2004
          • 5118
          Hth.
          Please dont tell me you have a few spare H&R's....?
          • Flat on my back
            • Jan 2007
            • 2449
            Pffffh...
            I wish...just standard aby non aircon.
            Carlos.
            • mcandmar
              • Apr 2004
              • 5118
              Ah ok. You can get lucky sometimes, i found a pair of Konis in the S2 struts i bought
                I had this on my coupe springs, the rears and the fronts fitted in different orientations to sit correctly with the flat coil lowermost and the helical coil uppermost! Very strange!
