I've been trying to find some info about 4x108 to 5x112 conversion, so far I found how to do the conversion on 10 and 20v CQ's, the question I have is, what bits except hubs would I need to do this job on 2.8 CQ, do I need s2 drive shafts or are the same as s2?
You could get that wheel in 4x108. Optional on the very last of the cabby's.
One you can call rare.
Were a couple of users on fans a long while back, one that was bullied into taking pics with the centre cap off to prove
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
B2 Quattro
B3 FWD
B3 Quattro/Coupe
B4 FWD
B4 Quattro/Coupe
Can Josh,Richard,Slab and others who have performed this conversion state what is needed,especially for the FWD guys?Part #'s would be greatly appreciated.
Thanks alot.
B2 Quattro (4000S)
FRONT:
1. UR-Q complete assembly
2. Convert to...
here you have
I did almost the same thing,on the front -S2 hubs with housings,7A axes and joints
on the rear I pull'd out the 4x108 hub and stick in the housing hub from A4 1.8T quattro 1995 ...This is it
p.s. the A4 hub is 8 or 9 mm wider ,than others!
Regards!
