Hello all, Need new Farb and bushes, whats the best to use, how much and where from?.
FARB for my 3B
I have a used one from an Avant if that's any good for you ? It's in very good shape, no rust, stored in dry place.Midnight Blue S2 - SOLD - 1993 S2 Avant -
Stock is fine
Limited options up front, RS2 is about it and they're £250 new. Might get lucky on eBay.de but more than likely end up with an S2 bar
Suggest you give the current one a lick of paint and get either superflex or powerflex bushes and some RS2 drop links on there to tighten it up a tad.
Then spend the remaining £225 on a rear setup, there's the B3 22mm FARB (Error404), B4 22, 24, 25, 26mm FARBs (me) and the Whiteline RARB to choose from, check out the sticky in the chassis section. Only option that's not covered there is to take an FARB and cut it down to the same size as a RARB (this will make sense when you read the thread).Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
never heard of this before either in what way doe's it help. doe's it loose some of the under steer or just keeps the rear a bit more level. any links to a been there done that if it is a easy change i might make use of the spare front 3b one i have in the parents shednever set your expectations to high that way you are never disapointedComment
forget that i just read the rest of your last postnever set your expectations to high that way you are never disapointedComment
crap that i missed out on 3 S2 FARB,s for 35£ each the other day then..Comment
oh yeah another thing... is it a straight swap FARB on rear that is.Comment
To put an FARB on the rear you need to swap the struts left with right to relocate the drop links. It's all covered in the sticky in the chassis/suspension section.
Removes a lot of understeer, can be a little twitchy on track with lift-off oversteer (even a stock coupe suffers from this if provoked) but a small tweak to driving style gets it flowing nicely.
There are now 3 additional options to the Whiteline for the rear of a coupe, as detailed in the thread here.Cheers'en, AndyC
