lowering discussion
  • geryS2
    • May 2006
    • 814
    • Home: Belgium Current: Portugal
    lowering discussion
    Hi all, would like to lower the avant but on a budget,
    spax, H&R, eibach, bilstein ? what s best combi springs-coil , would like a -30 mm kit
    what s the advantage of coilover vs separate coil & springs ? as for price is double i think.
    S2 's and oldtimers
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    i want to do that to my rs2, but i dont like the idea of 30mm lowering. I already have bilstein shocks and S2 avant HR springs(springs not fitted yet) but i also had custom modified some OEM springs to 15mm lower only.Im going to try those on first,and then if not satisfied i will go for the S2 HR springs. I believe it is the best compromise however it may make the car unable to go over speed bumps or go on ferries without front bumper touching the ground
    • Rusty
      • 18953
      A set of springs and dampers are about the same cost as a set of KW V1s, £800 or so, so why not just get some coilovers and set the rideheight to stock or wahtever lowering you require?
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        because KW i think the highest you can get is -30mm or something and they are much stiffer than bilsteins to begin with.At least that is what a friend told me when he used them on his RS2 and went back to original shocks again
        • Rusty
          • 18953
          Might be worth speaking to KW direct?
          • geryS2
            • May 2006
            • 814
            is it possible to make OEM springs custom modified ??
            what kind of mechanics can do that ? and can we still keep the standard shocks while lowering 15 mm ?
            i had that i think on my beloved destroyed previous S2 and it was perfect, by the way on another S2 coupe with H&R -30 , it s ok for bumps, only think is when u ride on bad roads or in a hole in the road !! bang, shocks hit the bottom and ur wheels and tyres suffer much more.
            Keep me in touch with your custom made suspension, could go for the same.
            Thanks
            S2 's and oldtimers
            • Azman
              • Sep 2005
              • 3205
              Oo got one does the RS2 ride lower than S2? I have RS2 front shocks on stock springs just wondering if I can lower and get away with it (if the RS2 rides lower that is)
              Dark Grey Avant
              RS2 FARB
              Alloy Subframe Bushes
                RS2 springs are the same as S2 Avant aircon ones. The shocks are harder however
                • dest
                  • 4287
                  For lowering on a budget you cant beat H&R springs
                  Before:
                  After:
                  • iDub
                    • Oct 2006
                    • 182
                    How are you h&r boys with speed bumps? Mines on h&r/minis and I scrape my exhaust just behind the front wheels over pretty much every bump! It looks pretty though...
                    Audi S2:
                    Avant! Ye scurvy landlubber...
                    • dest
                      • 4287
                      Mine only scrapes on really big speed bumps, but since swapping the cats and resitting everything its doing it even less now as it doesnt hang down as much
                        Don't go there, I'm going back to standard ride height. Birmingham is a nightmare
                        I should then have 2 sets of lowering springs to sell, well that's the plan!
                        • Christophski
                          • 3632
                          Jamo how much do u want for a set for an avant if u have 1?
                          • Gompa
                            • Oct 2008
                            • 285
                            what about koni inserts then? i was looking at uprating my dampners as they feel very soft and the car crashes a lot on bouncy b-roads. Im running H+R springs on standard S2 avant shocks.
                            The only ones i could find were on german ebay and were about £700 so makes me think why dont i just save a bit more and get some coilovers (H+R's or KW's)
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              there are a few shops in the UK that can heat modify the springs to make them lower. they work on race cars so i trust them
