After the disaster that was my alignment attempt I've got to take some remedial action before another go. Basically the front bushes are trashed, and the bolts to adjust everything are seized solid.
I've just bought some powerflex bushes for the wishbones, so I'm going to have a go at fitting them next weekend. One thing I noticed today, is that I couldn't get a spanner on the nut inside the subframe, so couldn't undo. I'm assuming I need a swan neck spanner. Is it a 17mm that I need? Once off, I assume it's a case of burning out the old bush, then cutting a groove into the inside of the metal sleeve to allow it to compress enough to remove. Do the powerflex replacements go in by hand?
And now onto the rear - how do I adjust the toe? I want to do a quick alignment by eye/tape measure as I can't get the cash for the alignment for another month or so. The toe is currently set at about 2 degress each side! So, does anyone have a photo of the rear suspension with a big arrow pointing to the toe adjustment bolt(s), plus a quick guide on how to do it. It doesn't look like the front setup so I'm not sure how to do it. I also need to know exactly where to empty an entire can of plus-gas!
Thanks in advance guys,
Matt
Matt
) I believe the powerflex bushes just press in, however its easy enough to make a tool out of a length of threaded rod, some nuts, washers and old bushes for less than £10.
