My car has progressively developed a strange "bounce" from the front wheels.
Upon deceleration or braking should you hit a bump on the road the front left wheel goes into an un controllable bounce which only stops when speed is reduced.
The un sprung part of the suspension and wheel seems to be involved in this wheel hop phenomenon.
The car is fitted with Konis and H&R's springs and I assumed it was the shocks.
At the same time i replaced the top mounts and removed the konis for inspection.
The konis seem to be ok after a test and speaking to the local agent for koni.
The konis wher originally set on a very soft setting so after the inspection i turned them up harder to 3/4 stiffness and put them back on.
I now have the same effect but much worse.
Any advice ?
Any advice ?
