I have STFA. Does anyone have any recent experience of new/recon pump prices please ? Mine has always made a clackety noise but its now REALLY loud and I had a strange start up the other day after some very heavy rain blowing into the front of the car ; no PAS. I opened the bonet expecting to see a broken belt but all was fine on restart.
Power steering pump - update?
Does http://www.isham-research.co.uk/quat...ulic_pump.html not apply?
The noise, BTW, is quite often the high-pressure hose - it has a constrictor in it.Comment
I really have been most dilatory in putting pictures up on the site.
Anyway, this pump is off a 20V urq - the front portion is wrapped in the rag at the top right - that's the metal-to-metal seal you have to be careful about. The back end is at the bottom, split to reveal the ******* Seal from Hell, which actually a doozie. Although it's rotationally symmetrical, there IS a right way up.Comment
All the S2s Ive owned have had the noisey belt, sounds like knackered tensioner bearings. I had the same and was worried, an old school mechanic said belt, I said no way is that belt noise, he sprayed some WD40 - noise gone!! The WD40 trick works but only for a short amount of time, sometimes just tightening the belt fixes it. Changing the belt is a fairly easy job.Comment
