Cast wishbones
  • Azman
    • Sep 2005
    • 3205
    Cast wishbones
    Morning all,
    Just a really quick thought thathas been bugging me for a while.
    Looking at cast wishbones correct me if I am wrong but they have the same alignment and central point for both left and right hand sides.
    So if that is the case, as on our cars we do not use the roll bar attatchment section, surely we can just flip a passenger side on to a drivers side by changing the orientation of the bolts that hold the ball joint??????
    I know it is mad but I have two passengers side ones in the boot of the car (been clearing out the shed) and just looking at them got me thinking a little bit.
    Cheers all.
    Have a look see what I mean.......
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • Azman
    • Sep 2005
    • 3205
    No thoughts on this???
    Dark Grey Avant
    RS2 FARB
    • K Simmonds
      • Dec 2007
      • 7627
      I've noticed the same thing with the pressed ones, not 100% sure if they could be used on either side but I don't see why not.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • Azman
        • Sep 2005
        • 3205
        Will look into a bit further then, goemetrically they are the same just the pins/bolts are on opposing sides making them handed and the "top" side has a larger protrusion around where the antiroll bar would have attatched. Will see how easy it is to remove the bolts
        Dark Grey Avant
        RS2 FARB
          Don't see why not. I'm using URq front wishbones on the rear of my CQ on the opposite side to normal as they are symetrical
          not sure how easy it will be to remove the bolts though as IIRC they are pressed in..
          • Azman
            • Sep 2005
            • 3205
            Bit of heat and a big hammer should do it Well my man down the garage is on it as we speak will report back after the weekend
            Dark Grey Avant
            RS2 FARB
            • Flat on my back
              • Jan 2007
              • 2449
              Medium hammer, no heat...i neeed 3 new ones.
              Carlos.
