Coilovers for the ur?
  • gavs20v
    • Sep 2004
    • 3057
    if theyre kw's then theyll be v3's. Carsten said they dont do v1 or v2's for the ur
    Gav
    S2 Cabriolet.........
    • steverrquattro
      • Oct 2006
      • 787
      Originally posted by Acidburn
      Sal's just placed an order for coilovers for on his ur
      Copy of message from Sal (Pearl) re. weblink in this thread:
      Originally posted by pearl
      I've tried that set up before using bilstein shocks on my s2, I could never get the handling/ride right using different weighted springs. My car would be either way too firm for road use or it would bottom out over small bumps in the road. In the end i got fed up of wasting money trying out different springs that I went back to h&r springs on standard platforms
      and then another:
      I've just sent a set of struts off to h&r for them to make me a set of coilovers. They werent prepared to do a set for an ur quattro due to low demand so I told them to make them using the s2 settings that they have but on urq struts if you know what i mean?
      In view of the latest information I think I'll wait and see what his comes back like.
      Steve
      1990 RR 20V
      1982 SWB UR - RS2 Engine
      • sal_s2
        • 1287
        The ones I wasnt happy with were the coilovers on the s2 that i had and took off. They qere a comp brake type kit.
        Doug at mrc has now sent a set of ur quattro struts to h&r on my behalf for them to make me some coilovers based on the setup that they normally use for the s2. The only downside to this that i can think of is that they'll be made for a car that is 200kgs heavier so they might be a touch firmer (which i dont mind).
        • lind4hl
          • Jul 2008
          • 2465
          sal, that is probably good, since most serious people in scandinavia thinks that the hr and kw kits are too soft at real track driving... for road use, ehrm.. not that fun
          • steverrquattro
            • Oct 2006
            • 787
            Sal,
            Do you know what the total cost will be for the modifications to the struts? Also, what springs and load weights for front and rear are you planning to use?
            Steve
            1990 RR 20V
            • sal_s2
              • 1287
              H&r are going to mod the struts and use whatever spring/shock combination that they use for the s2.
              I dont know what the settings are but if you speak to anyone who has them on an s2 they'll tell you how good they are
              • G60Rallye
                • Dec 2006
                • 1321
                Originally posted by steverrquattro
                Is this what you've used?
                Reason for asking is that I've had a chat with Sal as he's used these and in the end gave up as he just couldn't get it right and went back to Konis with H&R springs.
                I really like the idea of coilovers but I've not come across anyone as yet who've had success with the UR.
                It is what I am using yes.
                The UR strut is 54mm outside diameter once given a clean up with a flap wheel perfect for the compbrake sleves.
