Shock Shaft Diameter
    No idea, a picture would help me a lot or a diagram
    • lind4hl
      • Jul 2008
      • 2465
      *sigh*
      sitting on the wrong computer, anyone got a pic of a bilstein front shock that i can use to draw some things on??..
      • G60Rallye
        • Dec 2006
        • 1321
        The top hats that come with the compbrake 2.5" coilover kit fit the Koni damper shaft perfectly. They are ur quattro struts though, I dont know if they are a different diameter to an S2?
          Alex, do you mean the ribbed plastic/rubber bellows that sheathe and protect the shaft
          Oh, and did you get the shaft diameter of the Billies?
          • lind4hl
            • Jul 2008
            • 2465
            Andy, yes that is what i mean
            i did not get the shaft diameter, as im in norway again...
              I understand. That part is worth keeping for a road car although on my car they never stay in place very long, despite using cable ties...
              I was looking at a bump stop that is part of the top mount or one that is interal in the spring coupler for helper springs. Would keep the coupler centred on the strut as most I've seen seem to kink.
              • lind4hl
                • Jul 2008
                • 2465
                thought the bilstiens had bumpstops built-in??
                  Yeah, I guess they must, that's a fairly simple delete though as the inverted billies are different diameter to all other shocks. My Konis for example need bump stops and are the OE diameter.
                  • raymor
                    • Sep 2003
                    • 597
                    Bilstein - Inverted - nominal 40mm shaft and the top hats that come with the compbrake coilover conversion fit fine.
                    1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
                    1987 CQ85RS
                    1994 S2 Avant- Gone
                    1991 V8 -Gone, but lives on in the TDi and CQ
                    Fintray Hillclimb - 33.20s
                    Doune Hillclimb - 55.02s
                    Forrestburn Hillclimb - 52.61
                    • Lago Blue
                      • Jul 2009
                      • 843
                      Bilstein F4-P36-0370-HO shaft photo
                      Please ignore the none CQ parts. This is the nominally 40mm OD "shiney bit". You can see the boot-top retaining groove. Top threads are hidden by the washer. Draw away sir!
                      • Puglife
                        • Jun 2006
                        • 731
                        I've designed some custom adjustable top mounts for my mk1 golf. M14x1.5 top thread with 40mm thread length but i need to get custom shafts made longer. The shaft diameter i have here is 22mm....
                        My top mounts allow adjustability for camber only but i've designed a weld in top plate for round turrets (type85 quattro rears are 182mm diameter).
                        Jay - pug_life85@hotmail.com
                        1986 Audi UR quattro - WORK IN PROGRESS
                        1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                        • s2driveruk
                          • 12696
                          yup billies do have internal bumpstops...as i found only after i bought new oem ones and someone told me that they wouldnt fit and i didnt need any for that exact reason
                          1992 3b S2 Coupe
