Just about to connect the above up.
Just a few questions.
What order should I tighten the above up, drop links first, then nuts bolts on arb bushes. Or tuther way round? and does car need to be down on wheels, or up on stands when tightening all the above parts.
Ta for any reply's.
rs2315.
Ta for any reply's.
rs2315.
and only applies if you fit the original rubber bushes. If you've been sensible and changed to poly ones then you can do them up in any position.
