Just upgrading wishbone bushes to Superflex ones and have checked all the various places for torque settings on the wishbone bolts and now I'm confused
Mike's site shows 40 Nm + 180 degrees for his front bones which are cast/forged...ok
.....and 70 Nm + 90 degrees for his rear bones, which are pressed. So far so good.
Paul's site shows 40 Nm + 180 degrees for his front bones which are cast/forged...ok
Then we go to the Bentley manual section 40.30 (for the CQ), which shows pressed steel front bones and gives 40 Nm + 90 degrees.
My 4 bones (1994 ABY Coupe) are pressed steel and take SPF1428, which is 8A0407181.
So my logic is that they should be the same as Mike's rear pressed bones, which also take 8A0407181 bushes and therefore should be 70 Nm + 90 degrees.
Can anyone confirm? BTW some of the bolts are real boogers to get (e.g. O/S front bone rear bolt) at whilst others are p*** easy (e.g. O/S front bone front bolt)
Cheers,
JB
Cheers,
JB
