which wheel bearing ?
  • s2jake
    • May 2008
    • 13
    Hi guys.
    Im trying to find a front wheel bearing for a 93 couoe 2ltr 16v.
    Local motor factors say it's not listed and on ebay there loads with little info.
    So a point in the right direction would be a great help...
    Cheers..
  • baltiboyS2
    • 965
    Just get one for a 80 2.0 there the same or 80 tdi etc etc will get you a aftermarket part number tomorrow what make are you wanting
    IMA
    SKF
    FAG
    QH
    cheers Raj
    • caterpillar
      • 2480
      bearing
      warning: there are 2 different whell bearing for the audi 80... one have the smaller 75mm bearing, and some have the 82mm...
      • caterpillar
        • 2480
        the 4 syl DOES the smaller one; outside diameter are 75mm
        • baltiboyS2
          • 965
          right part numbers and prices below they only keep 2 type in stock but they can get the others
          Just go down to your local motor factors with the numbers
          FAG 713610080 £25.62 + VAT
          DRIVEMASTER DWB683 £16.16 + VAT
          Cheers Raj
