Is there any good after market items availiable? mine are bad and im not paying dealer prices!
Rear tie rods
Tags: None
Would be good if an alternative source of the balljoint could be found. Add that to these delrin bushes and we should have a better/cheaper uprated part. Dealer prices on them are horrendous.Paul Nugent
Unfortunately the front steering ball joints are too small to be used at the rear. They're short by 5mm and so the taper is too small. How typical!
You could use a rose-jointed effort but they can be a problem duew to poor protection.
The rear tie rod also has a strange bend in it, I can only assume it's for clearance but without a closer look I can't be sure.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
I've designed a set for my mk1 golf project (very easily adaptable to use on any quattro). A rosejoint affair doesnt need to be expensive, but durability is the key without going overkill. The taper situation is easily overcome and can be adapted simply enough. Reverse engineer it.
You can buy protective boot for rosejoint too Andy. Whilst not 100% sealing they offer considerable advantages over a stock balljoint/tierod.Jay - pug_life85@hotmail.com
1986 Audi UR quattro - WORK IN PROGRESS
1981 VW Mk1 Golf - "20v Jim, but not as we know it!"Comment
Looks like 034 sell them http://www.034motorsport.com/product...roducts_id=717
Anyone had experience with these? looks like quite a simple design.Comment
$330 for those.
I was looking at using some OE style rod ends and the poly bushes off Kev with a threaded, bent bar in the middle. Should be a little cheaper but I can't find a list of rod ends to get teh right size from...
I seem to recall the taper is same as a 100 front joint, however it should be a standard metric taper of some size so has be ball joint out there would work.
I always thought the crank in it was so if the wheel is hopped of a curb the rod wont bend rather itll spring back to original shape and also soften the impact of the bracket on the subframeComment
Kev's delrin bushes are a really good upgrade for knackered bushes. My rear tie rods were original when I refurbed them - boots were a bit tired but the ball joints themselves were fine - the OEM ones seem to last well.
on the type 89 coupe the rear tie rod is curved for a reason - under compression a straight rod will contact the passenger side chassis in a big way.
An aftermarket arm would need to be the same shape - wouldn't be that hard to design & build something tubular and i'm sure a pair would retail for under £100.
Mr Rusty I have a rear rod i can donate to research if K24R fancies a look........
Imola B6 S4 AvantComment
