Buy it from main dealer only!!! Although they are 10.9 not 12.9 which is stronger they come with a special coating to stop them rusting within 5 seconds from fitting. I had the missfortune of discovering what happens when the bolt rusts from age. Fortunately my experience was at 5mph pulling away from a light.
....and make sure it is done up properly or you get a nasty knocking noise from the suspension, and then have to replace the joint again as the pin has worn narrow(!).
