Does anyone know if the seals in the steering rack would be designed to seal when under full pressure?. I have recently re-built mine and have filled it with fluid to test it and it seems to leak out on the rack end seal as the rod goes in and out. Now at the moment it is not under any pressure and as you move it in and out there is evidence of fluid on the rod.
The seal itself is a hard plastic seal within a machined metal encasement with a rubber o-ring on the outside. The inner plastic seal has three notches leading upto the seal which makes me wonder if these are there to allow pressured fluid to act upon the seal and expand it to create a seal.
Has anyone who has rebuilt one actually checked it before running it and had the same action thatr has gone away when the power steering pump pressures it?
