should be as easy as fitting the brackets to the strut brace, seating everything on the car in the correct place then tack welding the brackets on (or seam welding if you want to) then painting over the welds once done.
I would do as you described with car on level ground and wheels straight, everything bolted together and sitting as you wish it to stay. You could cut the brace and weld in an adjuster if you wish, bolt on and you can adjust tension if it makes any difference.
The bit you are welding onto is double skin so I don't see it cooking the strut top mount however I would stuff the void with wet rags and keep a fire extinguisher handy just in case, its not going to be a massive weld but I would lay a damp towel/cloth over the surrounding metal a few inches away and cover anything that might get spatter on it.
you will almost certainly melt or set fire to the topmount if you do it with the car on the ground
When i did mine I put it on axle stands symetrically under the front chassis rails and removed the strut from the turret.
Then squared up the brace brackets with a laser level and tacked them, then bolted on the strut bar to hold them parallel and then stich welded around the brackets.
Good upgrade BTW, you will notice the difference
HTH
I painted the turret and bracket with weld-thru primer first, and also afterwards with some zinc primer. I've not "finished" it yet as i will be getting my engine bay resprayed when I do my engine convertion.
Factory used seam sealer around the joint and then sprayed over with paint
I had wet towels all over the engine bay and wing when I welded
i cut my brackets out of an S2 shell, so they were not the black factory paint, but you defo need to clean back to bare metal around the edges or you will not get any penetration from the welder
I placed the bracekt on the struts and drew around them with a marker pen, and then brushed the paint off the turrets with a wire brush on a drill. you need shiney metal to get a good weld, but you only need to do it withing a few mm of where you will be welding,,, if you leave the rest of the paint on it will be ok. If you use seam sealer before you weld, it will melt out of the joint and make a mess, and spit molten steel down your shirt... BTDT with the stich welding the chassis
As above then painted after welding and cleaning..... i still need to tidy up as mine are still paitned in primer
well im really afraid that rust will eat the metal from between the turret and bracket. there is the base factory pain on the brackets, but that is not much...
i will risk getting spit in the face with molten steel, rather than having rust nightmares at night...
Curious, i havent seen that version of the brace bar before, most S2's have a box section bar similar to yours but without the cutouts at each end. Also have a round bar version here but i dont know what car it came off. Yours is nicer though..
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
