which wishbones
  • denniselbows
    • 740
    which wishbones
    hi all just wanted to check if this is right , i have a 1991 3b coupe with cast wish bones at the front and pressed wish bones at the rear. have the rear wishbones allways been the pressed type or was there a cast rear type at one time and mine have just been replaced with a pressed type at some time. it's mot time coming up again and i need to replace the rear bushs and don't want to get any incorrect parts.
    thanks dennis
    never set your expectations to high that way you are never disapointed
  • Skull
    • 3506
    • Country: Slovenia
    rears always pressed
    Audi Quattro WR
    • denniselbows
      • 740
      thanks for confirming that didn't think it looked wrong i just thought the front was cast so the rear would be as well. every days a school day
      • Tonks4x4
        • Nov 2005
        • 3062
        If you find a second hand pair of cast ones they can be flipped over and used on the rear...
        Audi Nut!!!
          How? The cast front wishbones are not symetrical like pressed rear ones.
          • Tonks4x4
            • Nov 2005
            • 3062
            Flip them over and then fit them to the opposite side of the vehicle and use cast type balljoints and then everything lines up.
            Audi Nut!!!
            • Acidburn
              • 13459
              also curious about this
              • Acidburn
                • 13459
                interesting, do you have any pictures of this done?
                • Tonks4x4
                  • Nov 2005
                  • 3062
                  ******!!!! I hope I'n not giving away secrets now.
                  Here is a few pics under my shorty, And I have a set blasted up to put on my S2 aswell I just have not got the time to do it yet....
                  Audi Nut!!!
                  • Acidburn
                    • 13459
                    cheers for that brian, think i'll be giving that a go now
                    • europeanme
                      • Oct 2005
                      • 3817
                      looks like you are!!!...
                        have you measured up rear pressed wishbones and Ball joints against and forged wshbones and ball joints? They don't match up. I looked at doing this, but your geometry (set-out and rear castor angle) will be out by a lot.
                        On the WR and MBs the front wishbones are the same as type89 rear wishbones, so you would think they are interchangeable, but their front and rear ball joint offsets are different.
                        • Tonks4x4
                          • Nov 2005
                          • 3062
                          When I did it I had a pressed wishbone on the floor and then layed the cast one on top.
                          From memory the rear right for example uses a front Left wishbone and front left balljoint.
                          When on top of each other they were within a couple of mm...
                          Audi Nut!!!
                            hmm, mine were loads different, 15mm at least
                            You sure it was a type89 rear ball joint not a type85 front one you measured against?
                            You can fit the forged wishbones off a RR onto a WR or MB as the ball joint offset counters the wishbone offset compared to the symetrical wishbone and balljoint of the 10v cars.
                            Then compare the rear balljoint off a type 89 car against a front one off a 10v UR - its got loads more offset.
                            Have you got a pic side by side by any chance Brian? I'm confused!
                            • Tonks4x4
                              • Nov 2005
                              • 3062
                              I'll dig 2 setup's out later and picture them for you.
                              Audi Nut!!!
