pulling left under braking
  • urS6Tom
    • 773
    My S6 has never been the best handling car, but it's gradually getting better. Got the brakes sorted (AP 6 pots), Bilstein/H&R on the rear and the Sachs kit on the front (soon to be replaced to match rear), but I've still got the same problem I've always had - it sometimes pulls hard to left under braking.
    It doesn't always do it, and when it does it's correctable with the wheel. Question is - what could be causing it?
    As I'm going to replace the front springs/dampers soon I'd really like to get this sorted at the same time.
    Anyone had this before?
    Cheers,
    Tom
  • Fat Audi 80
    • 10547
    Suspension bushes worn on one side, ball joint excessive play, steering rack play?
    The Perfectionist
    • Rusty
      • 18953
      Road camber - try braking on the other side of the road and see what happens.
      Left front suspension takes all the loads on roundabouts, that will add up over time to uneven wear. Worth getting it all checked over for wear and alignment by someone you trust
      • spink
        • 4382
        Theres not much to go wrong on an S6 really,apart from the above check the arb bushes where they go through the bottom arm,i would say if they were badly worn it could possibly allow the bottom arm to move back and forward slightly under acceleration/braking.Also check the steering rack is secure,i have heard there was a recall on these where there was a strengthening plate attached to the end of the rack to stop it ripping through where it mounts to the inner wing.
        • URSIMPO
          • Jul 2008
          • 431
          sounds like your brakes are knackered, better sell em back to me
          • istoo
            • Mar 2006
            • 408
            i had the same on my urS4 which turned ouit to be the rear track rod adjusters.
            • urS6Tom
              • 773
              Ha ha - I've just completely stripped down the calipers, cleaned the pistons, replaced the seals, fitted new AP floating discs and Endless pads. They now provide some serious stopping power
              • urS6Tom
                • 773
                That's interesting - I certainly wouldn't have looked at the rear for a while.
                What was wrong with them? Adjusted incorrectly?
                • urS6Tom
                  • 773
                  Ok - will check all that. Cheers
                  • urS6Tom
                    • 773
                    Wasn't there a place near Bristol you've recommended before? Not sure whether it'd be better taking it someone who knows Audis rather than an alignment specialist?
                    • Rusty
                      • 18953
                      All Audi for mechanicing - where I purchased my car.
                      Either Protyre in Bristol or Miles Tyres out by Thornbury for alignment.
                      HTH
                      • istoo
                        • Mar 2006
                        • 408
                        Originally posted by urS6Tom
                        That's interesting - I certainly wouldn't have looked at the rear for a while. What was wrong with them? Adjusted incorrectly?
                        Hideously corroded! My car had been lowered and running urS6 wheels and the geometry hadnt been adjusted to suit. The were correctly adjusted just not for the current setup, if your with me.
                        • Nace20
                          • Jul 2007
                          • 721
                          • Country: Slovenia
                          do you have any pictures of mounting?
                          S2 limo
