Koni does not fit on my RS2?
  • snaak
    • 153
    Yesterday I tried to mount my new set of koni on my RS2, but the shock is about 3mm shorter than the origional shock. When mounted it sits loose. Is it possible that it should be mounted with a sort of cap on top of the damper?
    thanx!
    '95 RS2
  • chezz
    • Apr 2007
    • 440
    I think you need to shim it up with large washers.
    • Sonic
      • Jul 2006
      • 5514
      At the front only and between the top of the bamper and the screw-on strut cap, right? I had this problem fitting mine last weekend.
      You'll need to get some washers >3mm thickness and the same diameter. Error404 said he had some spare, worth a PM
      S2Forum.com Administrator
      • snaak
        • 153
        OK thanx, I'll give it a shot
        '95 RS2
