Powerflex set for 3B S2 coupe
  • Zeus
    • Jul 2007
    • 70
    • Country: Belgium
    Hello,
    I was wondering which bushes fit on my 1991 3B coupe so I can order them.
    As far as I can tell I should need these for a complete set:
    4 x PFF3-101 Rear Wishbone Bushings
    4 x PFF3-102 Front Wishbone Bushings
    2 x PFF3-103-25 Front Anti Roll Bar Mount
    2 x PFF3-105 Front Outer Roll Bar Upper Mount
    2 x PFF3-104 Front Outer Roll Bar Lower Mount
    Now for some questions:
    - What size mounts do I need for the FARB? Is it 25 mm?
    - Do I need the Front Outer Roll Bar upper and lower mounts? I don't see where they should be fitted in ETKA...
    - Anything else I should order while i'm at it?
  • andy10v
    • 5996
    The upper and lower mounts are for older cars where the arb was attached to the wishbone, the s2 uses droplinks onto the strut so you do no need those.
    Don't know arb diameter I am afraid.
    Depends how far you want to go with the re bush, top mounts, ball joints, track rod ends, rear tie rods, subframe bushes and then there is drivetrain. I would do top mounts as they are normally collpased. The poly bushes will show up/strain any other flaws.
    Sold ABY-stock
    • Zeus
      • Jul 2007
      • 70
      • Country: Belgium
      Does anyone know if the rear anti-roll bar made by powerflex also fit the rear ARB of the S2?
      The mounts I am talking about are PFR3-108-15 from http://www.powerflex.co.uk/products/...%29-202/1.html
      Thanks
      • Zeus
        • Jul 2007
        • 70
        • Country: Belgium
        No one has ordered these for their S2??? (PFR3-108-15) REAR ANTI ROLL BAR TO CONTROL ARM http://www.powerflex.co.uk/product-d...+Arm/1721.html
        Would like to know if they fit before I order.
