Removal and replacement of Avant Lower Arm Bush
    What's the best method to remove and replace the bush circled in the above picture?
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    When I did mine I think you can knock them out with a thin drift or flat ended punch,there are two small bushes in this part which aren't very deep.You might have to enlarge the hole on the bush to get access to the edge of the bush.Worse case scenario is to burn them out but that looks like it would spoil you paint job on the arm.
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
      It's not my arm just a pic , you can't burn them out or at least I can't see how, they are in a metal sleeve that presses into the arm.
      • dest
        • 4287
        Im guessing you need something like this to drive them out?
        I had to use one when I did the rear bushes on my vectra gsi
        http://cgi.ebay.co.uk/VAUXHALL-VECTR...item23096c3718
          There's a bush either side so you can't drive them through the hole, I'm guessing there must be a bush puller tool?
          • Skull
            • 3506
            • Country: Slovenia
            i have cut the sleeve on one side, and beat the bushes out...
            Audi Quattro WR
              Ah cheers Skull, so it's the old brutal the cr*p out of it
              • irishs2
                • Apr 2009
                • 2455
                Jamo, what are you replacing it with? An audi part?
                Eric
                95 S2 Avant under rebuild.
                • Skull
                  • 3506
                  • Country: Slovenia
                  yes, it is the "...use a larger hammer..." technique...
                  Audi Quattro WR
                    Yep
                    • Jonnybravo
                      • Aug 2008
                      • 2051
                      Big hammer mate, worked a treat on my own car.
                      • mcandmar
                        • Apr 2004
                        • 5118
                        I used an air powered hacksaw to cut the end off one, then drill, heat, and swear at it until you get one side out. Once you have one side out the other will come out with little effort.
                        Hard part is putting them back it, if you try using a vice the centre of each bushing will butt up against each other leaving the outer casing not fully pressed in. I bought a bunch of large washers that fit around the centre part and rest against the outer collar, there big *** washers.
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                        • europeanme
                          • Oct 2005
                          • 3817
                          amen to the almighty hammer!!...and press back in... jobs a good 'un
                          • denniselbows
                            • 740
                            i jot myself one of these
                            never set your expectations to high that way you are never disapointed
                            • denniselbows
                              • 740
                              should of be got one of these. makes life alot easyer when putting wheel bearings and bushs in. £240 from machine mart
