Does any one know if s2 hubs will fit a 1989 B3 audi 90 quattro as the wheels i want to get are the same stud pattern as the s2?
S2 hub conversion
in that case no as the CV splines are different. Also you will struggle to change the CVs as the driveshaft splines are different too IIRC.
Get hold of some CQ20v driveshafts and they will be plug and play as the gearbox flange PCD is the same on the KV and the 7A..... On the 7A the hub splines on the outer CV are the same as the S2.
I've got 2 front CQ20v driveshafts....
Imola B6 S4 AvantComment
HI
yes KV engine was in it ....i trying to do car up for a 3b conversion too at a later stage................its on 16 inch Auvs alloys at moment........check either my albums or john881000 i think i got pics of her there
otherwise i will post up later
cheers
john
