I'm working on a custom adjustable bleed valve on the hydraulic line from the pump to the rack, bleeding off pressure back to the return line to the reservoir. this will reduce the assistance at the rack and add some much needed weight to the steering.
I know there is a restrictor valve or similar in the factory feed line to the rack, does anyone have any details on it? IIRC removing makes the rack noisier?
