The steering rack on my 91 S2 is leaking a little bit of hydraulic fluid, giving me the occassional red warning light on the dash. I've been keeping an eye on it and topping it up about once every month or so with the Audi fluid, but apparently Audi now don't produce that rack anymore so I can't replace it.
I'm hoping it's just a seal that's gone - if that's the case, is there a way of replacing the seal and reconditioning it, or am I going to have to find a wrecked S2 somewhere and cannabalise it? Would that be expensive (the seal replacement)?
which is wrapped up safely for whenever I need it.
ops: The engine had move back and bent the rack. Quite rare for them to leak though... I would'nt replace the seals and refit it, you'll only find out if your repair has been successful after refitting, it's not exactly the easiest of jobs to tackle on an S2 with the engine in place. I would rather do it once and do it right.
