PAS Options for 20vT conversions
  • Ian Simmonds
    • Jun 2005
    • 2858
    We've been doing some more head scratching today about the PAS system. We're thinking about running the AAN's existing pump/alternator set-up with tensioner rather than backward stepping to a 'v' belt set.
    The question is, has anyone done this and if so, how did you do it. (we can get specialist pipes fabricated).
    If you've done the AAN into Ur and used the CQ/Ur pump, be interesting to also know how you've done that too.
    Kind regards in advance
    Ian
    93 MTMS2 Avant
    If it was me I'd use an electric pump Ian
    • spink
      • 4382
      where are you planning on fitting an intercooler Ian?,mine has got an aby/aan hybrid in and the ic is inbetween the headlights ruling out the pas pump in its normal place.i have an mr2 pump here which i may well use.Sometimes wish i had kept it simple but i like the idea of the aan inlet so its staying
      • Ian Simmonds
        • Jun 2005
        • 2858
        Hmmm... Someone else has just suggested that over on CA... I might need to investigate that... Thanks.
        93 MTMS2 Avant
        • Ian Simmonds
          • Jun 2005
          • 2858
          Being a RallyRep, there's going to be a fair amount of butchery to the front end which will become removable... But like you've said, we want to keep the format simple, so the intercooler will sit, broadly, where it would sit in the AAN. (although it'll have to be in a better airflow and better protected).
          93 MTMS2 Avant
