Coil Spring Rubber
  • th.b.w.
    • Nov 2006
    • 98
    Coil Spring Rubber
    Hi, does anywone know how to buy these coil spring rubber in europe ?
    Thanks Thomas
  • andy10v
    • 5996
    Search for spring assistors. Loads of hits on google, ebay etc.
    Sold ABY-stock
      what do they do?
      • th.b.w.
        • Nov 2006
        • 98
        Fine tune your spring rate for the perfect setup
        Increase Spring Rate Instantly
        Make quick adjustments during practice or on pit stops
        Used by virtually all Nextel Cup teams in every race
        it can make a stock spring stiffer for Trackdays....
        Thomas
        • andy10v
          • 5996
          Originally posted by Error404
          what do they do?
          I have used them to lift the back of a car with very tired old springs in the back, stopped it bottoming out over bumps and rubbing with people in the back. Cheap, quick fix.
          Some folk also use them in the rear for for towing, again cheap easy way of uprating the springs.
          Interesting if they work on track.
          Sold ABY-stock
            seems a bit of a bodge
              It does have a kind of 'team bodge' feel to it, but then again - if they fit nice and snug and have a variety of different rated materials then it could be a quick way to adjust spring rates - between road and track for example. Jury is out for me - would be good to see what sort of feedback folk have on them.
              • rj scotty
                • May 2006
                • 2195
                Had these on the rear of my slammed mk2 golf for years. They do stop it bottoming out even with fatties in the back.
                BUT I DON'T WANT A NEW CAR!
                1995 S2 Avant, Volcano Black
