Steering wheel too far away from you?
    Only people on the quattro forum think that as they not all very clever
    It works fine you just have to turn it the other way up (its symetrical unlike the coupe/S2 ones )
    • Skull
      • 3506
      • Country: Slovenia
      Originally posted by dkw_dude
      Hi, this seems like a nice mod. Is it possible to get the spacer for the steering wheel somewhere? I don't have the means to make one myself
      it is an awesome mod, i still run 5cm spacers and it rocks. you just need to get used to the distance from the steering wheel to the side repeater switch.
      find a company that has cnc machinery, thay can make them in no time, just unbolt the hub from the steering wheel, and take it to them for measuring
      Audi Quattro WR
      • dkw_dude
        • 555
        • Country: Norway
        Ok, thanks. OT:I modified the subframes of my Recaros and gained 3-4 cm of head space, that's also a good mod. With the steering wheel spacer the driving position will be even better
        Leif-Helge
        -91 S2 VEMS and Comp Turbo
        -12 B** 530XD Touring "S2 parts transporter, and daily driver"
        • tscheel
          • May 2009
          • 222
          • Country: Denmark
          Originally posted by mouse
          How is the seat dropped with normal S2 seats?
          Some info : http://www.s2forum.com/forum/showthread.php?t=29404
          Cheers, Torben
          '94 B4 Avant S2
          • bikerjim
            • Feb 2008
            • 1028
            Dragging this one back up. dont suppose you have a CAD file for the spacer ring do you Skull? Or does anyone know the PCD?
            • Sleeper_Avant
              • 2372
              im the opposite,
              stubby legs bring me too close to the steering wheel, like a bitch lol!
              • Skull
                • 3506
                • Country: Slovenia
                #22
                dont have it sorry, i took the hub to the shop and they took all the measures.
                i need to make some more for my other cars, this mod rulz
                Audi Quattro WR
                  Momo are 70mm pcd, I think others use 78mm but can't quite remember. For that size spacer, I'd put some counterbored holes and tapped holes, as per a wheel adaptor.
                  • afterburner
                    • Mar 2012
                    • 246
                    • Country: Bulgaria
                    #24
                    I'm running a 12cm spacer and it's still not enough for me I will have to also angle the wheel down few degrees because it's too high right now...
                    • GazzaG60
                      • 4133
                      seems we are a group of irregulars.
                      I got the short (***) straw. tbh didn't have an issue in the s2 or the 16vq one airbag one procon
                      • bikerjim
                        • Feb 2008
                        • 1028
                        Thanks for the replys guys
                        Andy, so do you think the PCD of the standard wheel like the one below is 78mm?
                        I'm gona take mine apart sometime and have a look! I have the seat about right but could do with the wheel a bit closer.
                        Also does anyone know a method of lowering the column a bit? Not wanting to go to the effort of fitting an s6 steering column!
                        • Acidburn
                          • 13459
                          How much lower?
                          btw did you get the pic I sent the other day?
                          • bikerjim
                            • Feb 2008
                            • 1028
                            Originally posted by Acidburn
                            How much lower?
                            Maybe about an inch at the wheel max, but anything would do. Last one I got was the interior shot.
                            • Skull
                              • 3506
                              • Country: Slovenia
                              #29
                              hope this helps...
                              btw the bolts are M5
                              Audi Quattro WR
                              • Skull
                                • 3506
                                • Country: Slovenia
                                #30
                                my spacers:
                                i use 2x 2" spacers, and it looks like this, i used two hub boots one over another...
                                Audi Quattro WR
