DIY Coilovers
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #121
    i know it can get to rocket science if you are building a car that is meant to do specific things. However, the setup of the original springs + bilstein shocks for my rs2 was ideal, with the only difference being that i would have liked the car slightly lower, NOT as low as H&R springs make it.
    So the use of DIY coilovers, to allow height adjustments to the above specs with slightly stiffer springs vs OEM, i would have thought it wouldnt cause too much of a change.
    i know some people when doing a change think of the motorsport spec that you would want every aspect to be crucially adjusted to earn every msec of every lap, but this is not one of these cases. I hope it works out as expected
      Its not just about maximising performance, you would optimise the ride quality by getting the dampers matched to the springs
      From what you are describing Vas wouldn't you be better off getting the standard springs rewound?
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #123
        i thought of that and before going for the DIY job, i had a spare set of coils, gave them to be shortened by heat (specialist shop) in the UK, by 15mm, that was done, and when fitted on the car, although the looks were great, the ride was awful. It was as if the car was sitting on jelly. It wobbled on all 4 corners. It was then that i was told, that lower the height, need stiffer springs by a 'X' percentage, and that is what we are going for.
          Sounds to me like they ****ed the springs when they modified them, IIRC they loose about 10% of their strength when they are hot wound?
          Maybe Driftin Jo or someone can tell you
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #125
            Who knows? Springs were used so maybe they had a bit of wear to begin with, even though they did measure them and had the quoted stiffness.
            I will let everyone know of how this goes
            sent with Nokia 5110
            • rs200
              • May 2009
              • 1398
              • Home: Croatia
              #126
              today I find out what have to do make coilovers good.
              for sleeve :
              there are lot of types aluminium . you must use aluminum Al Mg Si , because they are hardest , don't have cooper in side .
              and they must be HARD ANODISED to make hard surface , other types of aluminum can't be hard anodised.
              other part can be made from stenless steel , brass or polyurethane. don't use aluminium .
              I will post pictures when will be over.
              regards
              • jade
                • Jan 2005
                • 1811
                #127
                But if using B8 rather than B6 are they not made to compensate for lowering springs ?
                RS 2 580HP
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  #128
                  To me it depends on how much you want to lower it. For about 10-15mm it shouldn't make a huge difference. I could be wrong
                  • jade
                    • Jan 2005
                    • 1811
                    #129
                    Then B8 should be fine then, they are designed for a 20mm +\-
                    RS 2 580HP
                    • Majorcina
                      • Jun 2013
                      • 1334
                      • Country: Montenegro
                      #130
                      Lets bring in life this topic
                      I am planing to make DIY coilovers at some point,and a friend found me this thing,so i was wondering shud i buy it since its cheap?
                      Will this fit on my urs4?
                      I sopose i will need to cut the botom part where there is no thread?
                      Is it worth buying?(40e)
                        Might be worth seeing if you can check what KW part number they are to cross ref on their site
                        • Majorcina
                          • Jun 2013
                          • 1334
                          #132
                          Ill go check them tomorow and take a photo of it and ill post here
                          • hiloran
                            • Mar 2010
                            • 121
                            What stiffness of helper spring people have used they seem to be from 4 to 150LBS/inch. Any one tried to make progressive suspension with a bit stiffer tender springs
