Front Subframe Issue???
  • Fat Audi 80
    • 10547
    Originally posted by Sküll
    maybe it is a cabrio subframe?
    That is the best shout yet and would make some sense. Anyone care to look in the F.A. for me please?
    The Perfectionist
    • Fat Audi 80
      • 10547
      Late bump now that I have go my **** in gear and taken photos.
      If you see these strengthening webs on a subframe DO NOT try and fit it to your S2!
      The Perfectionist
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        #33
        Hey Steve, slightly off-topic, but is that the finish you get from POR15?
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • Fat Audi 80
          • 10547
          Yes, that is POR15 Chassis black. (This was after wire brushing and some Bilt Hamber hydrate 80 first).
          Cheers,
          Steve
          The Perfectionist
            its odd I don't understand why they bothered strengthening this subframe, presuming its for a V6 cab, its attached to the car via rubber bushes so I can't see it adds any rigidity to the chassis
            ....unless the chassis flexed that much between the subframe mounting points they needed to help stop the subframe cracking!
            • Fat Audi 80
              • 10547
              It is possible isn't it!
              They do suffer from scuttle shake apparently.
              The Perfectionist
              • PaulJ
                • Jun 2008
                • 253
                I use a different method which is easy and quick, Drill a hole through the rubber at 1 side of the bush, increase driss size until it has cut through the outer metal ring of the bush, hit with hammer, Doing the rear of my car at the moment, Upper rear wishbones need a 11 mm hole to weaken the outer ring sufficiently, does not mark the wishbone at all
                Holesaw will be a PITA as it generates heat and grabs
                Paul
                1995 RS2 Nogaro
                1971 Lotus Elan Sprint
                1974 Lotus Elan+2S 130/5
