lowering my "s2" limo
  • hermanio
    • Jan 2009
    • 800
    i have an audi 80 competition wich i rebuild to s2 limo. the car has a full rs2 drivetrain. as you can see on the picture the "problem" i have now is that the back of the car sits to high. my question is can i use 80 quattro b4 limo springs on the rs2 struts to lower the car a bit ?
    http://cgi.ebay.de/H-R-FEDERN-AUDI-8...ht_2089wt_1139
    5 Cylinder Freak
  • A80Avant
    • 10873
    • Country: Greece
    is this how it looks with original RS2 springs and shocks?
    • hermanio
      • Jan 2009
      • 800
      yes
      5 Cylinder Freak
      • A80Avant
        • 10873
        • Country: Greece
        if it is that high then with HR springs it should look awesome!
        • Skull
          • 3506
          • Country: Slovenia
          yes the springs will fit perfectly...
          Audi Quattro WR
          • hermanio
            • Jan 2009
            • 800
            hey skull, what springs are you using on the back ? or are you using coilovers ?
            5 Cylinder Freak
            • Skull
              • 3506
              • Country: Slovenia
              no, i am using KAW audi 80 quattro springs and bilstein B8 rear struts, which have been modified to allow a -2 +4cm regulation.
              Audi Quattro WR
              • hermanio
                • Jan 2009
                • 800
                do i get any problems using v6 springs ? because of the slightly lower weight of the v6..
                5 Cylinder Freak
                • Skull
                  • 3506
                  • Country: Slovenia
                  higher front...
                  Audi Quattro WR
                  • hermanio
                    • Jan 2009
                    • 800
                    but i also want al slightly lower front, not easy to find good springs i think ?
                    5 Cylinder Freak
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      this car in black its a near brother of mine
                      do you have it tuned??
                      • hermanio
                        • Jan 2009
                        • 800
                        only chipped, i think it would look so much better if the car would sit a little lower
                        5 Cylinder Freak
                        • Skull
                          • 3506
                          • Country: Slovenia
                          do it like me, bilsteins all around, and kaw 60/40 springs. on the front it will be just right with a little heavier engine,on the rear it is cool as with the mod you can set the height to match the front...
                          Audi Quattro WR
                          • hermanio
                            • Jan 2009
                            • 800
                            are you using these ?
                            http://cgi.ebay.de/KAW-FEDERN-Audi-8...#ht_2753wt_905
                            5 Cylinder Freak
                            • Skull
                              • 3506
                              • Country: Slovenia
                              yes those should be them, i dont remember if they were "s2" units or not, but all the rest is right.
                              they are not as hard as eibach springs
                              Audi Quattro WR
