steering bracket snapped
  • vonbeck
    • 2455
    can this be taken off and welded?
    top half has snapped
    ABY Cricket Green Pearl Coupe, blk leather
    THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
  • A1QSHIP
    • Aug 2004
    • 975
    Steering Brakcet
    Not worth the risk of it breaking again. Replace it is my recommendation.
    "Nulla tenaci invia est via"
    • mcandmar
      • Apr 2004
      • 5118
      For the sake of a few quid buy a new one, not worth the risk.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • quattrostyle
        • Oct 2006
        • 6229
        indeed, better change it. And if you go for a secondhand one maybe it's worth the effort to reinforce it.
        • BennyBoo
          • May 2011
          • 67
          Any welding on the steering componants is a MOT failure anyway..
          Scruff4 Lag Monster Noggy.
          In Progress:
          Volvo K24-7400/7000 hybrids, 2.4 heads, RS4 Rods, Tial W/G's + Screamers, True Dual 2.5" straight pipes :twisted:
          • Wiell
            • Aug 2006
            • 146
            how did you do that?
            • spink
              • 4382
              its not uncommon,i have seen other threads on this forum with the same issue
              • vonbeck
                • 2455
                Don't know just heard a sharp crack does anybody have the correct name or part number for it? And is it still available at the stealers or gfs etc
                • Jonnybravo
                  • Aug 2008
                  • 2051
                  I have one in the garage, £10 delivered. Will post it tomorrow for you.
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Well a weld should be more than fine.
                    And as for a MOT fail.... Well go look at any real race car you don't get the **** steering arms a S2 has that's for sure
                    Chef
                    • Jonnybravo
                      • Aug 2008
                      • 2051
                      Welded and after 17 years not a crack in them anywhere.
                      I have known cars to fail a mot for welded steering arms though so its a fair point, just depends if your mot tester knows what he is looking at or not.
                        That happened my typ85gt in dublin in a past life. Happened at very low speed thank goodness. Total nightmare. Count your blessings.
                          I have a brand new ABY one if you need it, £15 delivered
                          • vonbeck
                            • 2455
                            that would be great ta pm sent
                            • vonbeck
                              • 2455
                              i take it its just a case of undoing the four bolts and fitting new one? is there any thing to re-set after?
