Noisy alloy subframe bushes?
  • Colesy
    • Feb 2009
    • 2981
    Due to one noisy knackared OEM subframe bush I swapped the front bushes for alloy subframe mounts. The car now drives great and the old big clunk over bumps has gone.
    But now I seem to have different noises (small tappety clunks) from them at very low speed over bumpy - especially gravel surfaces. I've check all bolts and they are still fully torqued (80nm). All the other bushes and top mounts are pretty much new & the cv joints don't seem to have any play.
    So my thinking is that the metal on metal of the new mounts might be the reason? Is this a common problem or is there something wrong with my setup?
  • madpugger
    • Sep 2007
    • 1901
    ARB drop links?
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
    • irishs2
      • Apr 2009
      • 2455
      Check the exhaust down pipe, the slight different thickness of the top part of the alloy bush might have brought down the subframe a few mill but enough so the weld on the downpipe might touch off the subframe.
      Eric
      95 S2 Avant under rebuild.
      • Colesy
        • Feb 2009
        • 2981
        Originally posted by madpugger
        ARB drop links?
        They're newish as well!
        • Colesy
          • Feb 2009
          • 2981
          I'll have a look at this but tbh it doesn't sound as tinny as I'd expect the dp knocking to be.
          • Colesy
            • Feb 2009
            • 2981
            The downpipe clears the subframe by at least a fat fingers width so I'm sure it's not that. Any other ideas?
            • Colesy
              • Feb 2009
              • 2981
              Anyone else have any experience of this with alloy mounts?
              • mcandmar
                • Apr 2004
                • 5118
                Makes no sense, alloy bushes are solid so shouldnt make any sound. If your only hearing the clunking noise at slow speed or small bumps its either roll bar links or a worn out ball joint.
                91CQ20v - Gone to a new home
                93UR-S4 - The Magic Carpet
                94S2Bus - The Emerald Express
                • andy10v
                  • 5996
                  Did you do the roll bar bushes on the subframe?
                  I know you said most stuff is new but I would look at drop links and top mounts as they can fail early, or instantly if you got crap ones or an bad luck one.
                  Suspension wise there is not to much to check;
                  top mounts
                  wishbone bushes
                  drop links
                  lower ball joints
                  track rod ends
                  arb to subframe bushes
                  subframe bushes
                  inner steering rod bushes
                  I guess the solid subframe bushes will transmit anything more the rubber ones.
                  Sold ABY-stock
