Over the last few years it looks like the springs on the rear of my RS2 have given way; the car seems to be weighted considerably at the rear and the car seems to sit much lower at the rear than when I bought it.
Looking back at the history of the car I can see that Koni dampers & H&R springs were fitted; however, no specifics as to model or part numbers etc. The Koni rear dampers have been replaced also only a few years ago (suspension overhaul done about 7 years ago). I will look into whether any part numbers are visible on the non-OEM suspension components.
Having read through a few threads on the site, I think that it's possible that a set of springs from a S2 have been installed. As I understand the S2 front suspension configuration is similar to the RS2, but the rear suspension config is different. Is it possible that a S2 H&R spring kit had been installed on the car? If so would that account for the wallowy and much lower ride hight at the rear? And further to this, if the rear springs are replaced by springs designed for the RS2 would the gradual sagging be stopped?
The car has performed really well up until relatively recently when I've noticed that the rear has felt as I say wallowy. But the change has definitely been gradual.
Any help or advice would be much appreciated. R
