4 wheel alignment didn't go so well
  • gt2
    • Sep 2007
    • 28
    hi there!
    went to get my tracking done on saturday.....didn't go so well. apart from being well out, toe in at the front and toe out (by miles!) at the back, the rear eccentric bolts were seized in the rear track arm bush.
    so i'm ordering new eccentric bolts etc for the back, and it'll be going in to the garage to (hopefully) swap out the bolts etc.........
    but after a search i'm beginning to think i might need new rear track rods........is the only source for these the stealer?
    what about the front? do new front track rod ends come with the adjuster? are the adjusters available separately?
    oh, its an avant.
    ta
    You can buy them from quattro corner or eBay the s4 ones are the same if I was you I'd buy the Bambridge delrin bush for the track rods no seizing problems ever again
    • BRY
      • 3755
      That's a B5 S4 not a URS4.
