rear wishbone
  • bilko0795
    • Feb 2011
    • 1883
    rear wishbone
    Hi can anyone tell me how to tell the diff between the left and right rear wishbones with the ball joints removed. i have put the ball joints back in and have placed them on the bench with the joints faceing inwards and i have the medium size oval hole on the bottom as you look at them is this correct???????
    unless you have the Febi ones with the ARB bushes in them they are symmetrical, so fine either way up.
    In fact I have Febi ones on "backwards" due to my rear ARB setup.
    • bilko0795
      • Feb 2011
      • 1883
      Im new to the s2 only had the car 2 weeks not had a car with the quattro system before what are arb bushes and febi wishbones?????
        arb = anti roll bar
        Febi Bilstein
        • irishs2
          • Apr 2009
          • 2455
          ARB (anti roll bar bushes) Bushes. In relation to Error404 maybe he uses another type or rear anti roll bar off another car, which requires attachment to the wishbone directly?
          Febi is a manufacturer, making pattern or oem type replacement parts.
          Eric
          95 S2 Avant under rebuild.
          • bilko0795
            • Feb 2011
            • 1883
            thanks guys you learn something new everyday.This is why i joined this forum.
