Front end knock
  • 205gti
    • Jul 2010
    • 56
    • Country: Jersey
    Front end knock
    I've recentley developed an occasional knocking noise from the front end. It only happens when you initially press the brake pedal hard or come off the accelerator quickly. I've had a quick look underneath and couldn't see anything obviously wrong. Is there anything specific I should look for?
  • irishs2
    • Apr 2009
    • 2455
    My remote diagnosic psychic sock puppet tells me that it might be the top mounts , might want to take the plastic suspension top covers off to see the gap thats there:
    Or my sock puppet could be completely wrong, and it might be a snub mount on the front of the engine.
    Eric
    95 S2 Avant under rebuild.
    • 205gti
      • Jul 2010
      • 56
      • Country: Jersey
      Gap is noticeable on the left side and probably over a cm on the right. I guess it's time to change them?
      Also get a slight snagging noise when going to full lock on the right. Could it be linked?
      • irishs2
        • Apr 2009
        • 2455
        If its very worn then yep it could be moving in the top mount.
        Eric
        • Christophski
          • 3632
          Wow that is a good sock puppet. Can he tell me what is wrong with my T4 now???? Lol!
          Its an easy job to do with the right tools and doesnt take long either.
            If this is accelearion and brake related my gut tells me look at the snub mount and also the engine mounts.
            Check the IC for any pulley contact
            • irishs2
              • Apr 2009
              • 2455
              My remote diagnosic psychic sock puppet tells me that it might be a cracked vacuum feed going to the ECU.
              Eric
              • Christophski
                • 3632
                Have you been reading my thread as it could well be that causing my problem hence the load of silicone hosing I am waiting to get delivered.
                That psychic sock puppet of yours is pretty good at this!
                • irishs2
                  • Apr 2009
                  • 2455
                  Remote diagnosic psychic sock puppet is happy
                  l
                  Eric
                  • Christophski
                    • 3632
                    Your crackers! Love it! May be calling on the Psychic Diagnostic sock puppet again next week!
                    • 205gti
                      • Jul 2010
                      • 56
                      • Country: Jersey
                      Here are some pictures. Even if it doesn't solve the problem they look like they need replacing anyway.
                      Where is the best place to get them from?
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        Their knackered, quttrocorner is probably a good place to get new ones.
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                          they don't like they are tightened down as well as knackered I wonder if they have been fitted correctly
                          • fourringsrus
                            • Oct 2009
                            • 239
                            I'd be looking at wishbone bushes aswell, also the subframe bushes
                              yup they are defo fooked! the Meyle HD ones off QC are a good budget option.
                              GSF, ECP chinese knock-offs are *****, don't even bother IMHO.
