I am currently making some DIY coilovers. I have opted for the Bilstein dampers and approximately 300lb springs rates for both front and rear.
The question that I'm trying to work out is the spring lengths required. The original spring lengths are 12.5" front and 11.5" rear and I want the car to be lowered.
One other factor is that there is around 80mm adjustment on the front and approximately 110mm on the rear.
I have spoken to Demon Tweeks and they say to go for a one length spring rather than have helpers. Some of the feedback I've had from peoplle who have these SWB URs are running between 7" and 8" with helpers.
Having no previous experience of this, I'm just looking for someone to point me in the right direction i.e.
1. A one length spring, but shorter than the original and move the collar up so that when the car is off the ground the spring will not dislocate. Having said that I'm sure this will effect the damper performance as it will not allow it to fully compress due to the spring.
2. A shorter spring and helpers to make sure that when the car is off the ground the spring will not dislocate. Obviously this will compress under normal load and therefore make the car lower......in which case I could have stayed with the original set-up?
Help and advice please.
