855 407 365A ... from 1981-88 vw passat/santana..1981-1992 audi 80/90 with/witout q....
i have changed to the 3 boltpattern and 19mm tap from audi 80 diesel 1991-93...i changed the link too..
URQ balljoint PN 855 407 365 A and 366A... but i changed to 93 audi 80 controlarm with 3 boltpattern( and for the servo steering) 8A0 407 365 and 366... 19mm tap.remember the 93 controlarm are A-symetric (!!!!)
That 1993 Audi 80 Control arm, is it "bolt on" or not?
all controllarm will fit the small chassi... BUT you need to test out the use; and the space in the front fender; the asymetric will have the about 3 cm forward...and the 20v struth and bearing are stronger than urq...and you get 17+17 mm more space so the wheel are more outwards....; but no spacer
