On behalf of someone else, after a trusted 4 wheel alignment place near Glasgow.
Car is chewing through rear tyres and needs to be checked for axle position and incorrect settings and then set to OE factory specs.
i used ingrams in ayr (30 miles south of glasgow) for years, they've got a vw dealership & are a audi independent, was always cheaper than anywhere in glasgow
Kenny brown engineering in Hillington ind. estate.
Used to run Eagle rally services in the 70s and 80s.
Sets up all sorts of high end race cars etc!
Not cheap though!
In Larbert near Falkirk. About 30mins from Glasgow. Very knowledgable guy, have used him a couple of times as have most of my mates at some point, wouldn't go anywhere else!
Also he did the alignment on my friend's s2 after having KW coilovers fitted.
Anyone knows a good place for a 4 wheel alignment near Leeds for my 80 Competition?
Thanks!
Try an Audi garage. I was gunna get someone to do mine close where i work but at the last minute they cancelled It was probably a good thing, i thought i'd see how much my local dealer charges.
Turns out they have got new equipment and only charge £9.99 for a check and £89.99 for adjustment plus they cleaned my car inside and out, and did a bloody good job
After that comment Shaun i will give my dealer a ring as the price you mentioned is no more than most other places with the added bonus of a clean inside and out.That was on your S6??Update your thread.
They did say it was previously £250 but surprisingly nobody had it done. They have got new kit so they can do it cheaper now I suppose if that's the case, not all dealers will have the new kit so still be charging £250???? worth asking tho.
