Powerflex Anti roll bar
  • ThatGUY
    • Sep 2004
    • 794
    The RS2 front bar is 28mm and powerflex only make a 27mm bushing so I ordered them.
    The RS2 rear anti roll bar is 16mm... should I order 15mm bushings so that they are tight; or do I order 16mm bushings?
    Andrew
    //-\\ ((_)) //)) //
  • caterpillar
    • 2480
    they may makes " SQEEECY" sound... in the street bumps..
      Check out superflex too; they might help out. They're still quite flexible, so 1mm here or there isn't a big issue - just stick a chunk of copper grease in there
      I take it yours is a B4 chassis then?
        Superflex dont squeak from what ive seen. My powerflex's have been on and off the car 4 times and redesigned by powerflex, but they still cant stop them squeaking after a while, mainly because they were a high shore rating, or thats what I was told
