Hi Alex,
sorry for digging up an ancient thread, but I tried to be a good boy that uses the search function.
How do you think steering feel is affected by the fact that the torque applied on the strut by the tie rods has to go over the connection between the strut and the upright, these two M12 or M14 bolts. Isn’t that a real jump in torsional rigidity?
Sport Steering Rack
Got the transmission out right now and there's quite a lot of room, would make things a lot easier that is for sure
This...
If they say it's doable on my URS4 rack I'm in..
I have a spare rack I could send away and no rush to get it back...
I will be replacing shocks, subframe and all the joints around christmas.. it would be easier to fit it in that occasion (if you think it could be done by that time)
keep us informed!
P.Leave a comment:
keep us informed!
P.Leave a comment:
Also, Dave... I have a spare rack that needs rebuilt if you want to send it out as a core. Nice to have one on hand before you begin the job
The RS2 rack has a tighter ratio, not sure if that would affect the exchange.Leave a comment:
That's the best time, motor and trans out leaves all sorts of room.Leave a comment:
How much easier would the steering rack removal be with the transmission removed. I'm about to drop my transmission to replace the front seal and the clutch and from the looks of it I can get easier access to the rack. My rack is leaking bad and needs to be rebuilt.
Would I need to send my rack away to get in on this buy?
DaveLeave a comment:
I'll check your thread out, if it come's to it I reckon it can be done by removing the inlet manifold/dissy and completely removing the sub-frame. I do have the luxury of a pit and very nice tools so will try and do it removing as little stuff as possible for a challenge, perhaps aided by Benzodiazepine's
Too pull a rack again, I'd either be crazy or desperate. However, if it happens again, I'd pull off the head for access. Last time I pulled the motor, but with the head out and maybe the subframe dropped down an inch there should be plenty of room.
Would not ever even consider doing it without at least pulling the head, the way the tie rod bracket and hydraulic hoses are stuffed back in there is as tight of a fit as I could imagine. Even just getting the rack in place is a gargantuan task.
My build thread on my Cq has loads of pics of that nasty job, if anyone's stuck/interested.Leave a comment:
I'll be able to tell you in a week or so how I get on with changing the one on my 3B with the engine in place, my engine bay is somewhat simplified so has more in common with an ABY, no battery/procon ten etc.
I've stood considering starting the job a couple of time's but haven't felt brave or clam enough, maybe I should acquire some Valium or Xanax (perhaps both) before hand as well as a punch bag.Leave a comment:
Do-able - have something / someone around to kick when you get the rage on, oh and get a big box of plasters.Leave a comment:
