How to change the rear shocks on s6 avant
  • 220bhp
    • 2578
    • Home: United Kingdom
    Anyone have any idea on how to take the rear shock of an s6 avant.It seems impossible to accsess the rear top nut at the back of the spring,where it bolts to the body.any BTDT.
  • recurveandy
    • Oct 2006
    • 515
    Should be three nuts holding up the spring plate, two front, one back
    Bit of a fiddle but you can get it using a 3/8 drive with extension and universal joint
    Now from memory, the nut size on mine was odd, something like 16mm, or could just have been the rust. You'll want plenty of release oil on it and a good snug fit, not one you want rounding off. I had to hammer a tight socket over mine to get it off.
    1989 NG Q Pick-up (Daily)
    2002 ASZ Golf (Doris' Daily)
    1997 AJK-G2 A6 Avant Q (In surgery)
    1999 AGZ Bora (Daily 2)
    1994 ABC A6 Avant (Spare)
    1984 JS Coupe GT (Slow progress)
    1982 WN Coupe GT5 (Spare)
    1983 MK1 Golf GTI Pirelli (In storage)
      Originally posted by 220bhp
      Anyone have any idea on how to take the rear shock of an s6 avant.It seems impossible to accsess the rear top nut at the back of the spring, where it bolts to the body.any BTDT.
      As recurveandy has suggested, you have to remove the entire assembly, including the Item 17 plate, from the rear suspension to get at the top nut. You have to remove the three Item 27 nuts from the three studs that are welded to the body. Since they are welded and breaking a stud is kind of a disaster, soak the nuts and the studs with your favorite rust remover, e.g. Liquid Wrench, PB Blaster, etc. a few hours before you start the removal process. Take care to note the orientation of the Item 17 plate and mark it as left or right if you take both shocks off at the same time.
      This diagram might help:
      • 220bhp
        • 2578
        Many thanks,its of the car now
