Replacing suspension... How simple?
    Looking at replacing my old knackered shocks with Koni top adjustables all round along with new top mounts and possibly bump stops, depending on current condition. How difficult is the job and has anyone produced a definitive guide?
    BTW it's a '94 ABY coupe.
    Andy
  • porkkis
    • 1994
    Simple.
    Definitive guide:
    Jack up the car, remove wheels, unbolt brakelines from strut, unbolt ARB links and steering arms from strut, unbolt strut from hub carrier, put something under the wishbone so that the brake hose don't get stress, unbolt strut tops (front inside the covers, rear remove boot side trims - can be twisted out without removing the tweeter covers), use spring tool(s) to press the spring enough for it to be loosely in the strut, remove strut top nut nr2 (2 lug socket or similar needed), remove top mounts and spring, hammer the shock upper nut cap, try to loosen the cap, hammer, try, hammer, try, hammer, try, remove the shock, refit as per haynes way using new nyloc nuts only (note that some are non standard threads)
    Prepare to replace the shock cap nuts as they tend to be hard to get out, might need a saw. And the 2lug nuts too as if you don't have proper tools you need to hammer them out too.
    HTH
    • 91_S2
      • 612
      Originally posted by porkkis
      Simple.
      Definitive guide:
      HTH
      That was pretty definitive. One clarification. By spring tools, he means a "spring compressor".
      You will also need to get or make the simple tools to loosen the locknuts on top of the shocks. People have written this up somewhere else on this list. I took the opportunity to replace all the bolts on the strut. But I think they can be reused.
      The job is pretty straight forward.
      • Stick Insect
        • Dec 2003
        • 2338
        [QUOTE=91_S2] You will also need to get or make the simple tools to loosen the locknuts on top of the shocks. QUOTE]
        The tool is only cheap, I have one from Laser tools and it was £3 so isn't worth making!.
        I got mine from a trade warehouse but your friendly local car accesory shop will be happy to order it for you. The bloke doesn't have much to do apart from wear a brown storeman's coat and smell of cats.
        HTH
        David
        • 91_S2
          • 612
          [QUOTE=Stick Insect]
          HTH
          David
          Cheers David,
          I wish things were as easy to source here. If I could have found one for 3£ you can bet I would have done it. I spend 15 minutes grinding away parts of a cheap 14? 15? mm hex with my Dremel. Where again did you find the little nipper?
          • towerhurst
            • Sep 2004
            • 21
            Andy
            andy if you want to have ago yourself ,drop in i"ll tell you how to do it,you will need my spring clamps (jon allaudi)
            • porkkis
              • 1994
              Rich, Hazet has one. Way more expensive than £3 but still decent ~15e. I try to remember to check the number for it if you're interested.
              And yes, spring compressor or clamp is the word. The definitive guide was written in about 3 minutes from memory so I had to take some shortcuts and not get stuck in thinking about the correct words
              • porkkis
                • 1994
                Tiny web surf session tells me that it's probably Hazet 2593-4
                • Martynf
                  • 1885
                  pretty sure www.justoffbasetools.co.uk had one for less than ten quid.
                  Martyn
                  www.vagparts.com
