I am planning on buying the variant 2s. Any experiences with the,, ride quality.. prone to blowing? Plus does anyone have pictures of them. I have seen pics of the intraz setup but have yet to se these.
KW Varient 2 Coilovers...Who got 'em?
Not sure if it helps but my girlfriend has KW Variant 1s on her A3 1.8Tqs and they work really well. –55mm drop but still good ride quality. Decided on Variant 1 to save setting up. The roads around here vary a lot. Here is a pic.Attached FilesSS -
I have those on my S2. Ride quality on bad roads isn't very good, but good roads and higher speeds it's very comfortable. The improved handling is awesome!Originally posted by brinskanI am planning on buying the variant 2s. Any experiences with the,, ride quality.. prone to blowing? Plus does anyone have pictures of them. I have seen pics of the intraz setup but have yet to se these.
The result is LOW =)
Cheers. That's a cheaper site than we found. Unless prices have come down in last couple of years. They certainly improved the A3 no end. Not sure what the Audi sports suspension was about. Scared the hell out of me!
Eibach ARBs next.
SSComment
[QUOTE=yoggi]I have those on my S2. Ride quality on bad roads isn't very good, but good roads and higher speeds it's very comfortable. The improved handling is awesome!
Hi, can you tell me if KW used your own cores to build your kit or did they use someone elses core from a previous sale to make the setup.
I am concerned if I send them a perfect set of strut housings they will hold them for the next sale then use the strut housings from a previous sale that may have been pre-prepped to make mine.
Zlobo has this setup, he recently within months recieved it. Send him a PMCheers mis amigos,
_AntonComment
yepp i got mine on the car.. i can add some pic tomorrow how it looks with wheals on.Attached FilesABT C5 Lord Of The Rings
2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
kostic.nuComment
yes they did.. for s2 coupes you have to send all 4 of them. there is odering number for 12mm and 14mm and them there is odering number for over and under 950kg i think.Attached FilesABT C5 Lord Of The Rings
kostic.nuComment
Hi,Originally posted by zloboyes they did.. for s2 coupes you have to send all 4 of them. there is odering number for 12mm and 14mm and them there is odering number for over and under 950kg i think.
Where are adjustments located for the compression and rebound? Are they at the top of the shock like konis?
Does the rear have an external adjustment so you don't have to take all the trim apart to get to adjustment?
Can any other dampner be used with these or just the KW set up?
What kind of retention is used for the dampner?
Are the struts cad plated or just painted?
Greg W.They can have my car when they pry my cold dead fingers from the steering wheel.Comment
its like koni, and the rear have external adjustmenst on top like the front one, I thin you can use any kind of damper it seams so,, the studs are cad plated.
/SloboAttached FilesABT C5 Lord Of The Rings
kostic.nuComment
