Urs4 front subrame bushes
  • Costash
    • 878
    • Home: Romania Current: United Kingdom
    Can someone confirm if they are only 2 bushes for the front subframe?THX!
  • mcandmar
    • Apr 2004
    • 5118
    Two pressed into the subframe, the rear two bolt to the chassis rails.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • Costash
      • 878
      Err... then they are 4 of them then;the 2 pressed in the subframe are link to the arms?THX!
      • andy10v
        • 5996
        Does this help?
        12 bonded rubber mounting front
        14 bonded rubber mounting left rear
        15 bonded rubber mounting right rear
        And the weird arb setup
        Sold ABY-stock
        • Costash
          • 878
          Thx Andy do you have any part no for number 12?THX!
          • andy10v
            • 5996
            From Vagcat (I would still order through the dealer or confirm the part no.)
            12 4A0399415B
            front /
            16 N 90479901
            washer
            A12,1X59X5 /
            17 N 90583401
            hexagon head bolt c/w shoulder
            M12X1,5X105 /
            Its free, sign up and you can use the parts diagrams.
            Sold ABY-stock
            • Costash
              • 878
              THX Andy!!
              • spink
                • 4382
                its well worth changing 14 and 15,most people dont know they even exist so never get changed.they are about £55 each
                  As you have found out, there are 4, two pressed into the front, and two bolted into the body (via the item 18 bolts). All bolts are stretch bolts and should be replaced.
                    C4 UrS Front Suspension torque values
                    This pdf will help you with the torque values for the replacement bolts and nuts.
                    • Costash
                      • 878
                      I already have 14 and 15 need now a pair of 12, front arms in the way and job done
                      Thx guys for all info provided!
