same sufbrames as a 20v coupe quattro?
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    I must change my subframes,they looks so rusty and i think,that after sandblasting,its gonna be fragile,because of loss weight and material . So do you know wich subframes are same as a cq20v ? I cant find in our country,so i am fiding different options,wihout customazing subframes
    here some pics
    Audi Coupe Quattro 2.3 20V
  • 90quattrocoupe
    • Nov 2003
    • 771
    I am assuming the car you have is a 3b, as I see no rear sway. So I am assuming this picture is of the rear subframe.
    All model 89 coupeQ, and B3Q should have the same rear subframe. You should try to get a later one, as it will have the rear subframe mounts locations on the rear subframe.
    After looking at your rust, thank heavens, I am in California.
    I just pulled the subframe from a late B3 in the JY, and no rust.
    Greg W.
    • Tom_
      • Oct 2007
      • 1301
      but you dont have a snow for a 4 months and there are salting the roads.I dont have a 3B .
      so all B3q and 89cq have the same subframe,havent it?
      • Nik0las
        • 1345
        • Country: Bulgaria
        Subframes are the same...
        • Tom_
          • Oct 2007
          • 1301
          every engine in quattro and models are same ,right?
          • Nik0las
            • 1345
            • Country: Bulgaria
            you ask about subframes right so please don't try to be funny....
            only difference is antirollbar mounts, if it doesn't have them you can customize it, if you know what you are doing...
            even more b3 80/90 quattro heve same subframe.
            • Tom_
              • Oct 2007
              • 1301
              but i thought (engine,model) that ,with connection of subframes.
              • 90quattrocoupe
                • Nov 2003
                • 771
                Only the front subframes are different. The ABY uses a subframe that has a different mounting location for the transmission, as it is a 01e 6 speed. The B4Q V6 uses the same front subframe as the ABY.
                Except for the late sway bar mount locations, the rear subframe on the Qs are the same for Coupes and B3s.
                Greg W.
                • JariP
                  • 192
                  All the V6 front subframes are not the same as ABY. Transmission mounting locations are the same, but there are other differences.
                  • Tom_
                    • Oct 2007
                    • 1301
                    i hasitate if i sandblasted my subframes or not,because they look rusty and i am not convinced if all the rust blows out.I cant find another subframes for sale in our country yet.
                    • 90quattrocoupe
                      • Nov 2003
                      • 771
                      ABY front subframe on a coupe. 8A0-199-313BC
                      B4Q, front subframe, N model and later. 8A0-199-313BC
                      Greg W.
