50mm or 55mm shocks?
  • Zeus
    • Jul 2007
    • 70
    • Country: Belgium
    I need to fit new shocks and don't know which size, the forum mentions both 50mm and 55mm as a possible dimension for the s2... But if I measure the strut, the inside is 50mm and the outside diameter is 55mm, the outside diameter of the shocks themselves is 50mm...
    So which would I need
    I am also going to combine koni's with standard springs, is this a good idea/setup? Or is it really hard/stiff? Bilsteins would seem harder according to some threads and I don't want it to be really hard.
  • Zeus
    • Jul 2007
    • 70
    • Country: Belgium
    No one knows?
    If the fronts and rears are the same, are they all 55mm?
    Also, are the koni's 55mm?
    I can't find it on their website, they are a bit scarce with info...
    I've already read pretty much every topic on koni's on the forum, but can't find the answer I need...
    • Rusty
      • 18953
      What year is the car? Is it ABY or 3B?
      Might get lucky and find someone with a strut lying about to measure
      • Rikki Kitto
        • Feb 2010
        • 6276
        I had a nightmare with mine, you are best off taking them off and measuring as 50 or 55mm units can end up on any year car really
        • Skull
          • 3506
          • Country: Slovenia
          you have to measure the outside thread, that is the side you are looking for.
          Audi Quattro WR
          • Zeus
            • Jul 2007
            • 70
            • Country: Belgium
            I have them off, I just need to know what to measure.
            Inside diameter of strut/ outside diameter of strut or outside diameter of the shock absorber itself... It's a 91' 3B btw.
            • Zeus
              • Jul 2007
              • 70
              • Country: Belgium
              Ok thanks, then I have 55mm, fronts are the same as the rears...
              I can get both koni's and bilstein for around 500 euros, what is the main difference between the two other than that the koni's being adjustable?
              Or does anyone know a place that sells them cheaper?:mischeif:
              • Skull
                • 3506
                • Country: Slovenia
                konis are harder, if you want more comfort then select bilstein
                Audi Quattro WR
                • Zeus
                  • Jul 2007
                  • 70
                  • Country: Belgium
                  Thanks
                  I ordered Bilsteins (I'm not a fan of a really harsh ride, don't want to go hopping over a railroad crossing with the tyres litterally not touching the road anymore )
                  • Skull
                    • 3506
                    • Country: Slovenia
                    good choice
                    Audi Quattro WR
                    • stocious
                      • Jul 2012
                      • 838
                      I'm having trouble getting shocks at the moment and need a bit of clarity, with the strut apart which threaded part do I measure, the strut tube itself where threaded at top OR the strut cap, sorry if this is asked a thousand times just had a pair of Monroe reflex wich were to skinny for struts, and now I've a pair of Sachs coming as per the boge shock part number that I took out and he says 50mm shock, can post the boge part number when I get home if it helps at all ?
                      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                      • irishs2
                        • Apr 2009
                        • 2455
                        Its the threaded section on the top, or the id of the strut cap. The shocks themselves are 49mm in diameter.
                        Eric
                        95 S2 Avant under rebuild.
                        • stocious
                          • Jul 2012
                          • 838
                          Will check when home thanks ,
                          • Skull
                            • 3506
                            • Country: Slovenia
                            Audi Quattro WR
                            • irishs2
                              • Apr 2009
                              • 2455
                              and the 55mm one just for completeness
                              Eric
