C4 UrS Servotronic Control Module info
  • K7ERG
    • 1711
    Think I have a few of them somewhere in the lockup. If needed.
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
    • ChrisAudi80
      • Oct 2011
      • 236
      • Home: Norway Current: Thailand
      Craig
      Thanks for the offer. I will try Pop's spare one first. Its a little closer
      '96 UrS6 auto PRJ chipped E85
      '95 80Q AEB VEMS E85
      • popdemonic
        • Dec 2007
        • 1304
        • Country: Thailand
        Sorry Chris,I was driving on Bang Bua Thong-SuphanBuri Road and hard rain is pouring.I could not even see the front car taillight with
        max speed of wipers.
        one of a few I5 from Asia.
        • ChrisAudi80
          • Oct 2011
          • 236
          Oh, hope you got home OK. It has been hot and dry here all day.
          • ChrisAudi80
            • Oct 2011
            • 236
            #20
            Just to update:
            I bought a 392 (4B0 907 307) relay off Ebay. USD34 shipped to TH.
            Works like a charm.
              Originally posted by ChrisAudi80
              Seems OK.
              Just posting back the two photos
              The first side:
              The other side
                Just to update: I bought a 392 (4B0 907 307) relay off Ebay. USD34 shipped to TH. Works like a charm.
                Good news. Somebody on my home forum (quattroworld) tried a C5 Servotronic relay and found that it actually INCREASED the steering boost!! Oops. I don't recall which number it was.
                • ChrisAudi80
                  • Oct 2011
                  • 236
                  #23
                  I have not had servotronic working for a long time, so could not say if it boost more.
                  Steering is very light when parking, but the boost is not so noticeable when driving.
                  It does need getting used to. Steering with one finger. Have to be careful not going full lock.
                  • diesel des
                    • 3896
                    #24
                    so not all cars came from the factory with these?
                      No. Many did but at some point it was dropped from the S2 line. All the NAmerican UrS4/S6s got it. But I have decoded build tags from UrS owners elsewhere, e.g. a RHD 94 UrS4 in New Zealand that did not have it. The common code for Servotronic steering is 1N3, Speed-related variable steering assist. Straight up, no variable power steering is 1N1.
                      • Tommy200rs
                        • 285
                        #26
                        German MTM had hack upgrade offering at least to Audi S2 that made the servotronic boost aid smaller at higher speeds.
                          Okay. How about a link to more info on that?
                          • Tommy200rs
                            • 285
                            #28
                            I never had opportunity to open such control unit that had been modified. The basic functionality for V8 servotronic is described here: 119 selfstudy, table at page 15
                            It is about the "kennlinie" in page 15. Similarly that should be changed so that the disangement happens at prefered vehicle speed or the strength of the apply curve. The servo "boost" curve amplitudes (in mA) are modified in different servotronic ecu versions according to weight load in the front and prefered reaction to speed. I assume that at that time S2, S4 A100/A6 servotronic principle was like in V8 because the same solution design was copy pasted between different models in many cases. Strange that disengagement happens 180-200km/h, but not much earlier.
                            wires in page 18:
                            GND
                            + power for ecu and optional lamp engagement in different versions
                            speed signal input (like the same signal for motor ecu and stock radio and electric diff ecu at rear)
                            modulator signal wires (2) to servotronic valve
